Altair® Monarch®
Creating New Formula Columns
Creates a new column based on a calculation.
Steps
  1. Right+Click on a column and select Column > New Formula Column from the options that display. The New Formula Column dialog displays:
  2. Rename this column by replacing the name indicated in the Field Name field.
  3. Define the expression for calculating the new field value:
    • Select fields, operators, functions, and operators from the lists above the expression builder.
    • If you are new to expressions, read this page to help you
    • Refer to functions reference for a list and description of all functions you can use within an expression.
    Note that:
    • You can use the drop-down provided below the Functions column to specify a set of functions to display (e.g., Date, String, Numeric, Trigonometry, etc.).
    • As you define the formula, a sample of the output is displayed in the preview area at the bottom of the dialog box.
  4. Select OK to add the specified calculation as a new field to your table.
In this example, the first column (Amount) is the original column. Discount is a calculated field that shows the 10% discount value. It uses the following simple formula: Amount * .10:
Other expressions can look like this:
  • If(Customer="Ace Resellers",Unit_price*.55, Unit_price*.65)
  • FiscalWeek([Ship Date])
  • Replace(Contact,"Smith","Smith-Jones")
