Altair® Monarch®
Connector Dialog for ODBC
Enter values into the dialog box to connect and fetch data from your ODBC source.
IMPORTANT NOTE:
You must enable quoted identifiers (e.g. the options Enable Quoted Identifiers or ANSI Quoted Identifiers) when you configure the ODBC Driver to use with the connector.
For instance:
  • Microsoft SQL Server  DSN Configuration
  • ODBC SQL Server Wire Protocol Setup
Your connection will return a syntax error if these options are not enabled.
Options
Field
ODBC DSN
The ODBC Data Source you want to connect to. Select a DSN from the drop-down list.
Use Windows Authentication
(Available only when accessing SQL databases)
Option to allow the use of Windows credentials when accessing the database.
User ID
A valid User ID required to log-on to ODBC.
Password
A valid Password required to log-on to ODBC.
Test Connection
Click on this button to test your connection to the  ODBC Database
Load Table
Loads the tables of the Data Source. Tables are displayed on the Tables list.
Search Tables
Allows you to search for a specific table. Enter your search criteria into the search box.
Table List
Allows you to select a table. Check the box beside a table to use. You can select more than one table, and you can check the box beside Name on the header to select all tables.
