Altair® Monarch®
Connector Dialog for Business Objects
Enter values into the dialog box to connect and fetch data from your Business Objects data source.
Options
Field
URL
URL to connect to the Business Objects data source.
Port
Port Number required to access the data source.
Username
A valid Username required to log-on to the host.
Password
A valid Password required to log-on to the data source. This password must match the User ID above.
Authentication Type
Select one of the following:
  • Enterprise authentication
Use the system default Enterprise Authentication if you prefer to create distinct accounts and groups for use with BusinessObjects Enterprise, or if you have not already set up a hierarchy of users and groups in a Windows NT user database, an LDAP directory server, or a Windows AD server.
  • LDAP authentication
If you set up an LDAP directory server, you can use existing LDAP user accounts and groups in BusinessObjects Enterprise. When you map LDAP accounts to BusinessObjects Enterprise, users are able to access BusinessObjects Enterprise applications with their LDAP user name and password. This eliminates the need to recreate individual user and group accounts within BusinessObjects Enterprise.
  • Windows AD authentication
If you are working in a Windows 2000 environment, you can use existing AD user accounts and groups in BusinessObjects Enterprise. When you map AD accounts to BusinessObjects Enterprise, users are able to log on to BusinessObjects Enterprise applications with their AD user name and password. This eliminates the need to recreate individual user and group accounts within BusinessObjects Enterprise.
  • SAPR3
Use SAP R/3 Authentication.
Request Timeout
Amount of time the application will wait for a response from the Server before declaring a timeout error.
Connect
Click to connect to the host using the log-in information specified in this dialog. If the connection is successful, Universes available are displayed on the Selected Universe panel.
Selected Universe
Displays all Universes available in the data source you have connected to.
Select a Universe to display its items on the Selected Items panel
Selected Items
Displays items from the currently selected Universe. For each item, you can:
  • Set a display name
  • Define a filter condition
  • Delete it (i.e., not include it in the Monarch Data Prep Studio workspace.
Define or view properties as needed:
  • Display Name: Enter the name of the column to be used in Monarch Data Prep Studio. By default, this is the Item Name.
  • Item Name: Name of the column. This field is not editable.
  • Filter Operation: Select the operation from the drop-down list. The operations available are dependent on the column's data type:
  • Filter Value: value of the filter.
Note that all string values need to be qualified with the % sign.  For instance, to set a filter to display only Last Names that start with "SMITH", define the following:
LastName LIKE %SMITH%
  • Path: Location of the column within the Universe
  • Delete Icon: Select to delete the column from Monarch Data Prep Studio.
Filters
Displays filters that have been pre-defined for the currently selected Universe.
These filters are not editable but are displayed to help you verify the data that is displayed by Monarch Data Prep Studio.
Preview Data
Click to fetch data using the credentials and criteria you have specified. 10 records are displayed to allow you to verify that you are selecting the correct data.
Validate
Click to check that the query created is correct.
