Adding File Metadata Columns to Tables
There may be instances when your analysis will require the use of file metadata. Data Prep Studio provides an easy means to add the metadata of Excel, delimited text, and PDF/PRN files as columns to your tables.
In the Prepare window, select the table with metadata you wish to include in your table. At the bottom of the Change History panel, click the Metadata Columns button.
You can also expand the context menu of any column in the table and then select Column > Add or Remove Metadata Columns from the options that display.
In the Add or Remove Metadata Columns dialog that displays, tick the boxes of each metadata item you want to bring into your table. Alternatively, tick the box for Name to add all of the available metadata items to your table.
Click OK when you are finished.
Metadata Items
The table below describes the metadata items you can add to a table.
File Type |
Metadata Item |
Description |
Excel/Delimited Text |
File Name |
The file path of the source file. |
File Last Modified |
The last modified date of the source file. |
File Created |
The creation date of the source file. |
Sheet Name (Excel) |
The name of the sheet from which the table was obtained. |
PDF/PRN |
Report File No |
Report File Name |
The file path of the report file. |
Report File Last Modified |
The last modified date of the report file. |
Report File Created |
The creation date of the report file. |
Report Page |
The page number from which the record was obtained. |
Report Line |
The line number in the report from which the record was obtained. |
Report Column |
The column number of the report from which the record was obtained. |
PDF Producer |
The PDF Producer of the report file. |
Report Page Count |
The number of pages of the report file. |
