Altair® Monarch®
The Analyze Drop-Down
The Analyze drop-down displays when you click the Analyze tab in the Data Prep Studio toolbar.
The Analyze drop-down is your take-off point for creating, viewing, modifying and managing summaries.
Options
Option
Summary
This drop-down allows you to select from multiple summaries which summary to display on-screen
Active Measure
This drop-down allows you to select from multiple measures which measure to apply to the summary
Add Summary
This button allows you to create new summaries via the Add Summary dialog
Edit Summary
This button allows you to modify summary definitions via the Edit Summary dialog
Manage Summaries
This button allows you to manage summaries via the Manage Summaries dialog
Drill Level
These buttons show how many drill levels there are in the selected summary and allow you to drill up or down as desired.
