Altair® Monarch®
Defining a Custom Table
You can define custom tables in the table panel. Create the table and define the header, row, and column values yourself. You can also use data on your document to derive the values of the custom table.
  1. Click New Custom Table on the action bar at the top of the Table panel.
  2.
    A new table, with its own tab, is added to the tables on the Table panel. By default, this table is named as: Ad-hoc table.
    Select Rename Table on the menu above the Table panel to rename the table.
  3. Enter your data.
  4. Initially, you get a 2 x 2 custom table:
    Take note of the following:
    • You can use the top row as a header.
    • New blank columns and/or rows are automatically added as you reach the left-most cell or the  bottom cell  respectively.
