Function: DegreestoRadians
Converts the value of an angle expressed in degrees to its equivalent value in radians.
DegreestoRadians(angle)
Arguments
angle is any number representing an angle value expressed in degrees.
Return value
This function returns a value in radians.
Calculated field example
To convert the value 360°, use the calculated field: DegreestoRadians(360).
The function returns: 6.28319 (radians)
