Copying Data in Columns
Copies column values or selected values to the clipboard.
Once copied, you can paste the data into another application (e.g. Notepad or Excel).
Select a column or drag-select a portion of the table.
Right-click and then select Copy to copy only the selected data or Copy with Headers to copy the data including column headers.
