Altair® Monarch®
Column List
Allows you to:
    • Edit column information:
      • Rename a column
      • Change the field type (text, date/time, numeric)
      • Set the format for date/time or numeric fields
    • Reposition (rearrange) columns within a table
    • Hide/unhide columns
    • Set name casing (proper case, upper case, lower case)
    • Apply selected format to all other fields of the same type (for numeric and date/time fields)
    • View the number of columns included in the table
RELATED linkS
